we were out this weekend and used the boat all day saturday. we were just getting ready to head in and the engine warning light came on and the alarm sounded about every 15 seconds. i stopped the boat and checked all fluids. temperature and oil psi was good. something did smell a little hot though. luckily we were close to the trailer so we made it in slowly.
i spoke with the mechanic at my dealer and they think the transmission cooler probably has debris in it. the lake did get really nasty as the day went on. they told me to remove the hose coming into the cooler and feel for debris. if it does have debris in it to clean it out as good as i can with my finger then maybe take the other hose off and wash it out. sounded simple enough until i went to remove the first hose. HOLY CRAP! i'm not sure it's humanly possible to get an arm in there and loosen the hose clamp. they obviously assembled it before putting the motor in. Of course the clamp screw is on the opposite side.
I guess i'm just making sure there isn't any other options to try first. i worked on it for about 30 minutes on my lunch with no luck. i'll try again this evening. they suggested putting a fresh water strainer on to help prevent this in the future. any suggestions would be be very much appreciated.
Oh yeah, the boat is a 2014 z3, with the indmar m60 415hp.
