Not an engine/mechanic kind of guy so these things are fairly foreign to me. Have a 2008 20V w/ MarineMax engine. Is this an open or closed cooling system and how do you tell. Currently on Tablerock Lake and there is a ton of debris everywhere in the water from the lake being up 12' right now. Not sure if I picked up something in the water or bad gas... running sluggish but not overheating so sure would like to think water in gas..
20V Open or Closed Cooling Sytem ??
An 08 Tige would have had a Marine Power "brand" engine. They did offer a closed cooling 6.0L (i think) but not sure if the 340HP 5.7L was offered in a closed/saltwater setup. What horse power engine is it and can you post or link to pic of it?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Here you go.. Thanks for the help.
https://goo.gl/photos/Npxvs6KsZB9JBFpP6
https://goo.gl/photos/QwBxPmK2B45xRH1r6
https://goo.gl/photos/dMXLnHWKCXLRSjbn8
https://goo.gl/photos/d9dxEaJMRNtqNkqE8
https://goo.gl/photos/DyevDx8w53Dd92w39
If you need other angles of pics let me know. Appreciate the help.
Yesterday it died on the water.. Took a little while to get it started. Kept wanting to die. Finally got it going and it ran sluggish. Threw a couple cans of Seafoam in it to help out with possible water in fuel. Sitting at the dock running it to get that Seafoam mixed and below 2200 RPM it runs a little sluggish almost like its missing but when I push it above 2200 it smooth out considerably. Also.. It is not running hot. It is a touch below the middle line on the temperature gauge.Last edited by Cubacheski; 07-26-2015, 01:52 PM.
yep, open cooling 340.
When was the last time the boat was fueled?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
