Amperage on Tsunami Pumps?
    Does anyone know where I could get a replacement power line for a Tsunami pump? The part that goes into the cigarette lighter on the boat is rusted and one of the tabs completely rusted off so you have to sit there and hold the thing so it makes decent contact to turn the pump on.....
    Blue Sea Systems 1010 for the plug and 1011 for a new receptacle
      Chp to the rescue again!
        I needed a replacement on short notice last year and ran to radio shack. Cost me more but didn't have to wait a week to get on the water. Just make sure you got the right fuse in it.
        Just cut the wire and add on the new part. The one I bought just had push terminals. If I pull on the wire to hard I pull the wire out sometimes is my only complaint.
        '99 Tige 21v MercCruiser 350 MPI
          And the pump is rated at a 3.5A draw.
            I bought some cheap ones off of Ebay. I should have asked CHP! I suspect the Blue Sea ones are going to be a little higher quality. Mine are not fused, but the outlet itself is fused, so I am not too worried about fusing the plug as well.
            Be excellent to one another.
              Thanks guys! I got on Amazon and the Blue Seas is on Prime so it will be here tomorrow...boat won't be out again till the weekend so plenty of time to get it swapped out so I'm not "jiggling" the line all the time to get a good connection...
