My boat just went dead seems like has no power to starter but voltage is good. All Gage's are working touch screen is powered up but when you turn key nothing happens anyone else having this problem
Help 2015 z3
Originally posted by tonka8ty View PostIt just clicks once and then nothing battery's good all have 12.5 volts when trying to Crank starter it has 12 volts. What happend was we were cruseing down the lake about 25 engine revved like prop fall of so I instantly pulled back on throttle and shut key off and now nothing2011 Tigé RZ4
www.re-viveupholstery.com
My new Z1 wouldn't start after 30 minutes of bouncing across the lake. Starter would engage but not long enough to turn the engine over. Had to be towed in. Then after a 3 hour trailer ride home it started. As mentioned above, Indmar had a service bulletin out to move the ground. Dealer did the work and that seems to have fixed it.
The dealer will be able to get you fixed up. Kill switch and throttle placement make sense, but why would it rev to high rpms? Might be something with the electrical shift. Something happened to make it rev like it was in neutral then when you dropped it to neutral, the switch isn't reading. The signal might think it's still in gear and wont let the boat start.
Let us know what you find out.
