7000 ft...geeze louise...that must be friggen cold all the time LOL
Wake9 AVX Experiment: The Skinny Test
Originally posted by ragboy View PostNope, but I have spent too much money. ;-)
I have attempted your ballast setting and found a couple issues.
Speed was at 11.5, Taps at 2, Avx at 9.
We were leaning approx 9 -10 degrees until the wave cleaned up on goofy and 8-9 degrees on regular.
The boat had the nose about 7 degrees higher than the aft.
We had 6 people in the boat, 100% full front, 100% full surf side, 50-70% full counter weight, 300 lbs of lead in the rear surf locker, 50 lbs of lead at the front of the Xl sack. I had most of the passengers line the surf side in the back.
The wave had great push and shape in the front but a bit the wave seemed quite short and had very little push in the back. The wave also seemed a bit...soft..
I didn't get any good pictures of the wave but I was hoping for a few hints.
a couple of things, on goofy, balance your people weight more to the front, not the rear, and if you have a decent amount of people, but a body up there. If the wake is soft, speed up a bit.
Also, we have found AVX varies with weight, so if you use more/less people, AVX may need to be different. Still getting all the details. wake worked GREAT for the competition, one of the true real world tests.http://wake9.com/
Originally posted by ragboy View Posta couple of things, on goofy, balance your people weight more to the front, not the rear, and if you have a decent amount of people, but a body up there. If the wake is soft, speed up a bit.
Do you remember what angles you had the boat at? I am wondering if having my nose 7-8 degrees in the air is too much.
Originally posted by ragboy View PostDon't remember front to back, but I have pictures I can find. Sounds too high, need to get weight forward on goofy.
Thanks for checking!
Originally posted by dj2 View PostWould it be the same for an 08 RZ4? Between fighting with the swim deck and the prop wash I am extremely jealous of the regular riders on my boat. I usually run 11.5 mph, 1000 lbs in the right rear, about 200 lbs up front and have everyone in the back situated to get the boat listing 9-10 degrees.
If you have not installed a large surf flap, you should consider it. The flap can extend past the back of the deck, eliminating lip turbulence (but not the over sized deck interference). It also does wonders for prop wash.Last edited by Duncan; 06-01-2015, 09:35 PM.
The regular side was at 7 degrees of list with Taps at 3 AVX at 5 speed at 11.4
Goofy was 9 degrees of list, taps at 3, AVX at 8 speed at 11.4.
The wave was solid between 10.6 and 11.8. Boat was super easy to dial after we had a good base line.
