OK, so I was out on Saturday at the hyperlite demo and I got a chance to check RPMs at various speeds. Elevation is at 2300 ft at rollins lake, where I normally run at 800 feet. I didn't notice any difference. Haven't checked gas yet.
This is RJ surfing on goofy side, and you can see 11.8 MPH, which is definitely on the faster side, and the RPM is not even 3100. Picture taken when everything was stable, so accurate. Weighting is with new larger sacs, probably ~3500 lbs or so of water, and then 1000 or so in people.
Photo-2015-05-16-16-58-06_7565 by wake9, on Flickr
Here is 11.4, same weight.
Photo-2015-05-16-18-03-10_7583 by wake9, on Flickr
So then I dumped ballast and did my normal HEAD HOME speed, just chilling, not to far to go. About 3100 RPM and just under 20MPH.
Photo-2015-05-16-18-26-35_7585 by wake9, on Flickr
Then I went for what I would consider a good cruise across the lake, close to 25mph. This is that speed that felt like everyone is chilling in the boat, and no one is holding on to their hat, you know what I mean.
Photo-2015-05-16-18-27-14_7586 by wake9, on Flickr
Its not really broken in yet, so I didn't want to go WOT, but I did get it up to close to 35MPH and it felt like I had a few MPH left, I bet top speed is around 37-40.
Those are very comfortable speeds and so far I have not sensed even minuscule slippage or cavitation with this prop even when fully weighted and at higher speeds. We haven't tried surfing yet at 13 mph, but it feels super solid and much better than the 1235.
I gotta think that the Indmar 400, with the extra torque is playing a strong role in this. It reminds me of my F150 Ecoboost where I am towing uphill and it doesn't downshift, it just has buttloads of torque. The 400 motor just seems to never be working hard.
The other thing that is really interesting to me is how the boat is handling at low speeds, the more I drive it, the more I notice how much different it is. I gotta think this is all due to the prop, but could the torque of the motor have an impact on this as well?
As I said before, manipulating the boat around the dock is so much easier and positive, and there is never a need to burp the throttle forward to get the boat to turn. I just go into gear forward and it just turns, positively. I noticed something new, though. I normally have to sit in the ballast boy seat when surfing for obvious reasons. With this boat there is plenty of push so that I sat all day in the observers seat when surfing regular and I drove when going goofy. I have a brain block when turning the boat around after dropping the surfer. It is the proper thing to do to pull throttle up and let the boat naturally turn to the high side and let the waves pass you sideways with your high side facing the wave. I don't know if it is because I have ridden a motorcycle all my life or I am just mentally challenged, I ALWAYS turn to the lean without thinking, I can't help it. When I did this on the previous Z3, I would turn towards the lean and put in gear, and I would have to burp or wait a bit for the boat to turn because I am fighting the natural tendancy of the boat to turn toward the high side. This drives my son nuts, and now he is even more beside himself, because this boat doesn't care which way you turn. If I drop the throttle and then turn to the right (surfing goofy) and put in gear, it just instantly goes right.
I know that doesn't sound like a big deal, and I am not saying it makes the boat better or anything, but its a VERY noticeable difference and it is tantalizing my curious brain. ;-)
I would love to see the torque curve of the Indmar 400 vs the PCM 409. I am guessing the Indmar must have all of its torque down at the lower end where you want it, because the 409 says it has 492 ft lbs of torque, and it sure doesn't feel that way.
