The cover on my R20 tends to ride up over the rubrail when I'm towing. I noticed that there is a clip on each side right near the center of the boat. This spring I've seen a few picture here and elsewhere that appear to have a strap connected to that clip and then wrapped around the trailer (see images below). Are those straps intended to help keep the cover in place during trailering?
Cover Riding Up During Towing
Those side straps are for storage only to help keep shape when the cover gets rained or snowed on. They are not intended to be used while towing, the air pressure from towing will pull the cover down tight & can possibly rip the buckles out of your cover. I would also suggest tightening the ratchet up as much as possible & make sure you get the back buckles hooked on the tie down points.
i feel your pain! My cover always rides up a little right in that area. I tried straps there but they fluttered in the wind pretty bad and didn't like them rubbing on the boat. I've read other places to just let it ride up a little. it drives me nuts but I guess i'll live with it. Good luck!
Thanks for the feedback...
Good point, I didn't think about the straps flapping in the wind and damaging the gel coat. I tighten the buckel and usually check it part way through my trip. I only go ~80 miles in spring and fall and ~20 miles to and from storage, so I don't do a lot of towing. The cover overlaps the front of the boat well and with the back buckels around the tie down points it's not going to go anywhere. Just seems weird that it rides up above the rub rail about 1/2 way back. I guess others see the same thing so I'll stop worrying about it.
Boardman, I think I have seen in multiple threads here indicating that it is best to two without the tower strap. I have tried both ways and it seems to balloon less without the tower strap. Do the rest of you tow with or without the tower strap.
JohnnieMo, I use the tower strap if the boat has to sit out in the rain and it does a good job of keeping the cover up high enough so the water drains off.
Don't use the side straps, as mentioned earlier they are for storage. I do not use the tower strap either. It takes the place of the older style poles which you are not supposed to tow with. You want the cover to suck down into the boat. Do you have your docking cleats extended through the cover? If I have all four latched into the cover it doesn't move at all.Last edited by Iwndr; 04-08-2015, 01:34 AM."Failing to prepare is preparing to fail" John Wooden- Rest in Peace
Originally posted by JohnnieMo View Post
Tigé Jedi
- Jul 2010
- 4302
- TN USA
This thread started by talking about towing, but seems to be addressing water pooling too, so... didn't your cover come with adjustable poles that raise it up and keep water from pooling? Mine did and they work pretty well once their height is adjusted properly.
Our previous boat lacked those poles but we solved the problem with two big beach balls, one in the bow and one in the rear passenger area. Same effect of making the cover convex and causing the water to run off. It doesn't take much.
I do have a pole but I find it only marginally more effective than the tower strap (and far more challenging to install). Beachballs though.... that's a clever idea. I've tried an assortment of sticks and supports with little luck.
My eventual solution is overkill but effective.
Apologies for the hideous Mastercraft.... it was the only model I could find.
Sent from my Passport
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Originally posted by JohnnieMo View PostBeachballs though.... that's a clever idea.
What graphics program is that?
It is called Sketchup. Originally built my Google and now owned by Trimble. Free to use for personal projects. It has a steep learning curve, but once you get started you can build almost anything. There is also a large database of 3D models that can be shared amongst the user community. I managed to find my three cars and a boat that was close enough to check fitment.
