I was hoping someone may know what kind of pump this is, since my boat is a few hours away and I need to order a new one before it gets warm. The pic says 1000gph, and it's from what I believe is the rival ballast system on my 04 24v. Thank you!
They are Mayfair live well pumps, which has long since been absorbed by Johnson Controls and now under the SPX umbrella. By the looks of the manifold, it does seem to be a Rival kit. They have been out of biz for some time now. They were ahead of their time and went quite just as the aftermarket ballast craze started gaining speed.
Uh oh. I was hoping to be able to just replace the internal since the top unscrews and comes apart. Sounds like this may become a larger project than I anticipated.
The cartridge is replaceable, just twist it off and connect the wires. My 07 had the same pumps, just rated at 500gph. I still use them for the fill and drains on my bow sac, I just upgraded the cartridge to 750 I had kickin around from my old boat. You should be able to find replacement ones all over. Pretty sure even Walmart has them with their bilge pumps.
