So, I'm trying to figure out where I want to store my boat when it isn't in the water. I have space next to my house, only problem is, there is a side slope going away from the house. Basically, if I were to back up my trailer/boat next to my house, the trailer would be angled over to the right (right side of boat lower than left). Would parking the trailer (with boat on trailer) do any damage to the trailer and/or boat?
Storage on a Side Slope
Well, it would be parked there pretty much all the time. The overall plan is to build a retaining wall and fill it with gravel to level everything and make a decent parking spot but in the interim I was trying to figure out what to do..... I might just park it over a the parents house until the wall is built....
Originally posted by BurnMac42 View PostWell, it would be parked there pretty much all the time. The overall plan is to build a retaining wall and fill it with gravel to level everything and make a decent parking spot but in the interim I was trying to figure out what to do..... I might just park it over a the parents house until the wall is built....
that's a decent incline and I would worry about the skeg protector hitting while backing, otherwise as long as you keep the cover supported and dump any rain that collects on it you shouldn't have any issues. If you could fir the boat up on the low side it would be helpful and cause you less anxiety as you are already seeing it as an issue.
Tigé Junkie
- May 2013
- 920
- Central MN
If you don't mind parking on the brick sidewalk, and would park close to the house it would really reduce the decline. Then, if you are good at backing should really be able to create a temporary ramp that would allow the other side of the boat to be raised. Even a few 8X8s together or maybe 4 6X6s to give you a 12X12 block could be dug in to lift the other side some. If doing this, I would either use solid bricks or solid wood."I think I am pretty smart for an idiot"
The brick I'm not worried about...that will all be removed (along with the board for the old flower area) so the boat will be able to be as close to the house as possible. Looking at it again now that it isn't snowy out I might store the boat over at the parents house where they used to keep their boat until I build a retainer wall and level out my parking space......
Don't forget to check if there are any restrictions on parking vehicles outside of the garage in your neighborhood. Or if your parking bay needs to be paved. Had a friend that got in trouble for not checking with the neighborhood convinces and pulling permits doing the same thing."You're rather attractive for a beautiful girl with a great body."
I would park at an angle so the transom is lower than the rest of the boat. Then you can have the only Tige V- Drive that drainsUnless you have a center drain plug, Tige's take a good 2-3 inches of water before they reach the transom drain plug.
If he has an on board charger and a couple bilge pumps (on of my bilge pumps Tige or previous owner already put in that corner of the bilge).... should he be any more worried than an owner mooring their boat?Mods: MLA BIG Ballast System (1800+ Custom sacs, 2 500 W705 sacs under bow), Duffy Surf Flap Mod, Trimmed Swim Deck, Top-Mount Starter
