Auto trans, I always back down in neutral. Do not need reverse power and one less thing to go wrong.
Am I that green?
Makes sense for the manuals to be in neutral and I've never thought about putting the auto transmission in neutral. I guess it can't hurt either way. The boat ramp I use most often has a very shallow approach angle and I have to use reverse to get the rig moving. I had the trailer brakes stick there one time and I had to use the manual lockout pin to back up to the water.2009 RZ2, PCM 343, MLA Surf Ballast, Premium Sound.
I can see putting it in neutral being safer. My wife almost severed my arm off when she thought it was in Drive and she hit the gas and the truck and trailer came back so fast that the bow of the boat squeezed my arm up against the winch so hard I thought I was going to be a lefty.
Will have to try it this upcoming summer."You're rather attractive for a beautiful girl with a great body."
I do the neutral trick as well however, I tell all my buddies who are putting me into the water to simply stay in the truck leave it in neutral (feet on the brakes) and when i'm done and clear from the boat trailer (boat in water) all they simply have to do is put it in Drive and pull out..It pains me to hear them put it in Park and the whole weight of the truck, trailer, and boat hanging on the tranny, then the clunk when they put it back in Drive to pull out. It can't be good for the tranny IMOP2010 Tige RZ2 "Fully Loaded" 650hrs
Surf Ballast & Enzo Bag - 1235 prop
Tigé Jedi
- Jul 2010
- 4303
- TN USA
When parking on a hill (not just on the boat ramp) with an automatic transmission, I always shift into Neutral (not Park), apply the parking brake, take my foot off the brake pedal and let the vehicle body to shift due to weight redistribution, and only THEN finally shift into Park. This guarantees you won't have all that force against the pin in the transmission. The parking brake is holding the vehicle, no strain on the transmission, and the transmission is acting as a backup if the parking brake fails. I totally agree, I just can't stand the sound/lurch that happens when you take an auto out of Park when it's on a hill. It's so unnecessary. There is a reason auto transmissions have a Neutral position, though I rarely see anyone use it properly.
Tigé Jedi
- Jul 2010
- 4303
- TN USA
Many trailers don't have electrically actuated brakes. Mine, for example, is a surge brake trailer which is actuated by inward pressure on the towing hitch. Since backing down a ramp causes gravity to try to separate the trailer from the vehicle, the brakes are solidly OFF.
I have wondered, though... are electrically actuated brakes "normally on"? If so, how do you manually move the trailer when it's not connected to a vehicle? Say, to spin it around when it's just parked somewhere? Wouldn't the brakes be on? That would be a major PITA. If, on the other hand, the brakes are normally off and require electricity to actuate them, then backing down in neutral would work fine because the brakes would be off.
Tigé Junkie
- May 2013
- 920
- Central MN
Originally posted by WABoating View PostMany trailers don't have electrically actuated brakes. Mine, for example, is a surge brake trailer which is actuated by inward pressure on the towing hitch. Since backing down a ramp causes gravity to try to separate the trailer from the vehicle, the brakes are solidly OFF.
Ideally I would like to see a trailer that works with a brake controller. This would allow more braking on the trailer which would be better when cornering of sudden stops as the trailer could slow the TV and not push it. This is generally how I set up when towing our enclosed trailers at work."I think I am pretty smart for an idiot"
My case in point is the Hayden lake boat launch. It has a long flat approach to the ramp and there isn't much pitch on the ramp either. I usually back up on the flats, then stop for a second while the wife grabs the lines to the boat, this is when I disconnect the hitch from the boat, just as it's about to hit the water, and then I finish backing in the rest of the way. When I get the boat deep enough and I can see the bow raise just a hair, I jam on the brakes and the boat floats off, then I shift to drive and park the rig while my wife walks the boat out to the end of the dock, so the next person can get their boat in.2009 RZ2, PCM 343, MLA Surf Ballast, Premium Sound.
Tigé Jedi
- Jul 2010
- 4303
- TN USA
Interesting. It's been my experience that surge brakes don't restrict backing up on level ground. I do have to use the little mechanical lockout bracket when trying to back it uphill to where I store it in the summer. But when I was winterizing the boat in the driveway, I would have to back it up the "ramp" from the street gutter to the driveway and while that is most definitely an uphill in reverse, I never had any problems.
Because of the way the master cylinder in the tongue is set up, these systems are naturally proportional - i.e. the more force they feel, the stronger they put on the brakes. I wonder if you are on level ground and just going really easy, if the brakes are on so gently that it doesn't really have any effect? Just trying to explain what I've experienced.
Originally posted by WABoating View PostInteresting. It's been my experience that surge brakes don't restrict backing up on level ground. I do have to use the little mechanical lockout bracket when trying to back it uphill to where I store it in the summer. But when I was winterizing the boat in the driveway, I would have to back it up the "ramp" from the street gutter to the driveway and while that is most definitely an uphill in reverse, I never had any problems.
Because of the way the master cylinder in the tongue is set up, these systems are naturally proportional - i.e. the more force they feel, the stronger they put on the brakes. I wonder if you are on level ground and just going really easy, if the brakes are on so gently that it doesn't really have any effect? Just trying to explain what I've experienced.My parking lot is very flat.
Tigé Jedi
- Jul 2010
- 4303
- TN USA
Agreed on the tandem axle - but heck, those don't even need the brakes to be aggravating! Once the two sets of tires get out of the same turn radius, the entire thing locks up even if the tow hitch isn't connected to anything. I never had a tandem axle trailer until the Tige... someone here on this site explained what the heck was happening when I couldn't move it around without a truck. Thanks again to whomever that was!
Tigé Jedi
- Jul 2010
- 4303
- TN USA
Originally posted by JohnZ3 View PostIf your surge brakes don't engage while backing on flat ground, they are probably bad or dry (no fluid).
