Does anyone else have this problem? When the boat is on land and you stand on the swim step it sort of bends and is bouncy. Yesterday we had the boat out and with all the ballast filled it Almost felt like the swim step was loose. It was very bouncy and sounded like it was moving. I check art the screws that hold the bracket to the boat and the step to the brackets and everything was tight but it felt like it was not with all the ballast full. Now I do have the vx and I'm sure that holds a decebt amount of water in it just wondering if anyone else has this issue.
Also with the boat loaded with ballast the surf side of the swim step was under the water, is that normal?
I have the front filled, 400lbs total, then the back surf side filled stock setup, then had a 750 bag on the seat surf side. Had the offside filled with about 400 lbs, hard tank filled and about half of the stock back.
Had 3 adults and 2 toddlers on board and then me surfing
