So I've always just worked on the assumption that the swim platform was designed to pivot down for storage. It just made sense. But have you ever tried it? Well I did.
I removed the Vx as that is clearly in the way. I removed the middle bolts and pulled the pin. I then grunted and grimaced for a couple minutes to get the platform up out of its seated position. Then I tipped it down......
It hit the ground.
![](http://i1301.photobucket.com/albums/ag109/jmolberg/Mobile%20Uploads/IMG_20141009_161658_zps19ac2729.jpg)
Ummm did anyone think about this? The whole point is to easily allow us to store these things in the garage. Note that my boat is 23'10' while my garage is 23'. So I assumed a quick and easy pivot would do the trick, then back it in.
No luck. They add this pivot option... for what? What's the point? It doesn't add anything. I next tried lifting the platform up and hung it on the higher bracket and that got it off the ground... but still. This thing is far too unwieldy to make this a regular occurrence.
![](http://i1301.photobucket.com/albums/ag109/jmolberg/Mobile%20Uploads/IMG_20141009_161436_zps6e2f6075.jpg)
The other issue is now it's resting the on the Taps plate.
![](http://i1301.photobucket.com/albums/ag109/jmolberg/Mobile%20Uploads/IMG_20141009_161432_zps3a27cc4b.jpg)
I realize this nay be petty but I bought this boat with the assumption a smart engineer had this figured out. In the end I now need a major garage renovation.
Sent from my Passport using Tapatalk
It hit the ground.
