I had trouble with my perfect pass on the last run of the day at Mead. Turned out to be a minor issue. The wiring for the servo was blocking the throttle cable to the perfect pass.
Anyway, I have complained about the hour meter resetting on the dash but it turns out there is an hour meter on the Wakeboard Pro (older one). It was 2 hours less than ECU. Mine was on the build sheet was factory installed.
So for those looking at older boats, you can check the hours on perfect pass vs the dash if you don't have a computer (still recommend checking the ecu).
I think the command is up and menu to get to the menu for hours, voltage, temperature.
Anyway, I am just stoked I don't have to check my boat with my laptop to figure when I need an oil change
