I paid around $500 for a marine inspection and water test if thats what you are asking. I have heard others get it cheaper depending on the area.
Buying used 2013 z3 owned by wakesurf company
I worked at a dealer and I have never seen one rusted like that. That boat was ran in SALT!! If you are OK with that, then move forward but if not I'd move on. There is no way just the trans would be rusted if it was because the owner lived by the beach. Everything would have rust like that if it was due to "salt air". The trans is rusted because its the lowest point in the bilge and thats where the salt water hit. Thats not just one time in salt either. Thats consistent running in salt. Imagine what the inside of the motor looks like. Just a thought, because if they didn't wash down the bilge they probably didn't flush the motor either.
Exhaust manifolds are still raw water cooled IIRC, plus exchangerMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by boardman74 View PostI worked at a dealer and I have never seen one rusted like that. That boat was ran in SALT!! If you are OK with that, then move forward but if not I'd move on. There is no way just the trans would be rusted if it was because the owner lived by the beach. Everything would have rust like that if it was due to "salt air". The trans is rusted because its the lowest point in the bilge and thats where the salt water hit. Thats not just one time in salt either. Thats consistent running in salt. Imagine what the inside of the motor looks like. Just a thought, because if they didn't wash down the bilge they probably didn't flush the motor either.
2) If he had the PCM 409, isn't that half closed loop so the block SHOULD be ok? The exchanger, V-Drive, and Trans might be the only issue.
Bigdog, there is a user on here called Boatwakes (also a sponsor of the Mead reunion). If you are still interested in that boat, he maintains/services/repowers/etc on ocean boats in harbors in Southern California. I don't know if he does pre-sales inspections but it might be worth reaching out to him and see what it would cost for an inspection. He could likely give you a pretty informed opinion about the boat. Salt boats scare away a lot of buyers so my guess is that for an informed buyer, you MIGHT be able to get a killer deal. Boatwakes fixed my boat when I had trouble and I can't say enough about his expertise. He is also a fellow tige owner
My guess is that boat was used at Carlsbad lagoon. I was hoping for you it spent its whole life at Big Bear. For what its worth, there is some truth that things will corrode more quickly at the beach. The condensation every morning is salty.Mods: MLA BIG Ballast System (1800+ Custom sacs, 2 500 W705 sacs under bow), Duffy Surf Flap Mod, Trimmed Swim Deck, Top-Mount Starter
Just talked to the dealer again, said he just called the owner of the boat and he swears it was never in the ocean, which looks hard to believe however the trailer looks good, there is a little rust on the front swing away but none on the back of the trailer which i think would be covered in rust if it was used ocean frequently. The boat is down to 63k and has 57 hours on it and 1 year left of warranty and has over 3500lbs of ballast on it, 2 rev 8's, the stock 12" wet sounds woofer, wet sounds interiors, posident carpet, docking lights, underwater light, interiors light off of the tower, clamping board racks, surf bimini, and convex vx system.
Originally posted by Bigdog0598 View Postoh really? I was told by the dealer that they do transfer the warranty?
Originally posted by Bigdog0598 View PostJust talked to the dealer again, said he just called the owner of the boat and he swears it was never in the ocean, which looks hard to believe however the trailer looks good, there is a little rust on the front swing away but none on the back of the trailer which i think would be covered in rust if it was used ocean frequently. The boat is down to 63k and has 57 hours on it and 1 year left of warranty and has over 3500lbs of ballast on it, 2 rev 8's, the stock 12" wet sounds woofer, wet sounds interiors, posident carpet, docking lights, underwater light, interiors light off of the tower, clamping board racks, surf bimini, and convex vx system.
http://www.tigeaz.com/boats/
