2010 RZ2 wiring
    2010 RZ2 wiring
    Does any know or can look to see what the factory wire for the underwater light on an 2010 RZ2 is? I am installing underwater lights today, and would like to wire them to the factory wiring controlled in Tige touch. Thanks in advance
    I do not what color the wires are, but i am fairly certain that are labeled. They should be tied up to the harness along the transom. There may be only one pair, on the port side, not sure if the boat is prewired for both lights, even though its an option.
      Not sure about the 2010 models, but 13-14 models have plugs for 2 prewired. They are zip tied up above the batteries. Usually right about where it transitions from the center engine compartment into the small battery areas.
        Awesome, thanks. I will see if I can find them tonight. I didn't see any labeled previously, but I was also in a hurry to get in the water, and didn't expect them to be dummy proof and have labels. I will report back on labels / colors for the next person looking.
          The wiring diagram I have at my office might have these , I can check for you tomorrow
            Thanks for looking. I found the wires labeled transom LT, but it does not power the light on when the underh2o switch in the TT is turned on. It only powers up with the courtesy interior lights? I'm not sure if my wire is crossed somewhere? I will have to do some digging into it, but they will work for our Labor Day camping trip. If I need them off and the interior lights on for any reason, I will just disconnect the spade plug.
              Will find it regardless , 😊
                Will find it regardless , [emoji4]
                Thanks, I appreciate that! I would be interested to see if I just found the wrong wire, and there is another bundle tucked away somewhere that I'm missing.
                  Did you look and see if there was a fuse in the TT control box ? I wired some up for a friend at the beginning of summer and there was no fuse in the fuse box labeled transom lights.
                    I did not look. Did your buddies turn in with the interior lights and not the underh20 switch? It's getting power, but with the wrong switch. I'm kind of confused.
                      Not that I recall, but I don't think I ever turned on the courtesy lights either. I crawled under the dash and found the wire coming out of the fuse box, I think it was a dark blue labeled transom. I found that wire and a ground tied up in the rear starboard area . Wouldn't work, tried a couple different things... And then it hit me... Looked for a fuse in the box labeled "transom light" and it was empty. Threw a fuse in and it was GTG.
                        Toogrady fire me an email , will send you the wiring diagrams
                          That's awesome, thanks!
                            Z1 that diagram did it. The wire I had was gray and labeled transom RMT LT, and per your diagram it should have been blue. I hooked it up and I worked as advertised! Blue it is. Thanks!
                              Awesome glad I could help !!!!!now when I am in Washington state , you can buy me a beer and take me for a surf ,since I have yet to buy a boat !!.
