A couple of weeks ago we had our boat out (07' 20V) and it ran perfectly all day until the very end. At one point in the day a wave snuck up on us and came over the front of the boat, it was a lot of water, but nothing extreme in my opinion. The boat continued to run just fine for hours past that. Late in the day we hooked up a tube and started cruising back to boat ramp when the boat just shut down! Gauges froze and it wouldn’t do anything. Turned out the engine breaker (red reset button) had tripped. i chalked it up to the water that got in the boat cuz i don’t know any better. Fast forward to this past weekend... Surfed for a couple hours straight
, cruised around a bit, hooked up the tube, and next thing you know the breaker popped again, but this time no water had come in the boat.
After a few minutes i pushed it to reset and continued on our way... it popped again. Waited, reset it, and we pulled of the water. My question is what causes that breaker to trip? I’m not convinced that tubing is the cause... oh and all gauges look good when it happens (temp, oil, volts, etc.)
Thanks in advance for any advice or just taking the time to read!
