I just thought that I would share one of the best things that I have learned from this site, but haven't seen posted in a while, and it might save one of you a little trouble.
Flat tires seem to be a way of life for me. Maybe it was because I was driving from Lake Powell in the middle of the afternoon with 105 degrees outside, but my flat tire woes are subject of another thread. So I got a flat tire.
I don't keep a jack in the boat, who wants to do that? So here is what I did, sorry I didn't take step by step pics.
1. Loosen up bolts on the flat tire.
2. Find a rock about 3 inches thick, or a couple of boards, whatever you can find.
3. Put the rock next to your good tire (behind the rear tire if your front tire is flat, or vice versa)
4. Hop in the tow vehicle and pull forward until your good tire is on top of the rock.
5. Remove the flat tire and put it next to the good tire, with the outside of the rim facing up. (behind the rear tire if your front tire is flat, or vice versa).
6. Hop in the tow vehicle and drive the good tire on top of the rim of your flat tire.
7. Put your spare on.
Sounds like a lot, but in my case, it is easier than digging into the tow vehicle and using the crappy little bottle jack. If you don't get the good tire a few inches above the ground, then it probably won't roll up over the rim, but push it along the ground (I have tried that).
