Leaky help
    Leaky help
    Just need a little direction. Been working with the dealer with tige support which have both been great. Seems I get a leak when I fill up rear left ballast. Pumps and rear tank have been changed. Leak must be low as no water on floor. I'm thinking maybe one of the lines? Is It hard to lift the floor to get a look at all the lines. Can you take the top bag out and fill the ballast as bottom tank fills first? Prop shaft seal was replaced already and like I said only seems to take on water when left rear ballast fills. Ballast does not seem to leak after it's full.
    Any suggestions or other ideas?
    It's a 12 RZ2 with the wake makers 1100 sacs
    Thanks
