Can't figure out if I should have my wakeboard/surf rope tied in above or below our bimini. Started showing wear already having it over the top.
Surf bimini with alpha z tower question
Tigé Junkie
- May 2013
- 920
- Central MN
We use the sides to attach our surf rope, loop it through the opening on the tower...no issues. If pulling from the center for surfing we run it under. For wakeboarding we run it above."I think I am pretty smart for an idiot"
This is like the 3rd or 4th thread to ask about this, can you guys post up a pic of what's rubbing? I have the extended Bimini and I don't have any rubbing issues, are your biminis installed correctly? That's why I want to see some pics please.2009 RZ2, PCM 343, MLA Surf Ballast, Premium Sound.
Originally posted by Ewok View PostThis is like the 3rd or 4th thread to ask about this, can you guys post up a pic of what's rubbing? I have the extended Bimini and I don't have any rubbing issues, are your biminis installed correctly? That's why I want to see some pics please.Last edited by mnpracing; 08-05-2014, 01:40 PM.2013 Z3 - Electric blue and black
Originally posted by Ewok View PostAbove the Bimin. My tower has the standard tow point, light combo. I flip the tow point up for pulling, and flip the light up at night for required navigation lights.2013 Z3 - Electric blue and black
My rear Bimini poles have had a slight bend down since they came on the boat new. One common complaint about the early biminis is that some taller people hit their heads on the rear Bimini edge getting onto the walkover and rear of the boat. I'm 5'10" and it's not an issue for me, and I remind everyone who is new to my boat to watch your head, but at least the ropes never rub. Are your rear poles installed backwards where they make the back edge tilt up instead, which might give you room to route the tow line below the Bimini?2009 RZ2, PCM 343, MLA Surf Ballast, Premium Sound.
I also just looked on the Tige site of the stock photography for the Z3, and it looks like the same type of tow point that I've got on my 2009. Maybe there is an upholstery shop nearby that can put a slight bend in those rear poles for you guys so the rope can go over the Bimini with no rubbing issues.2009 RZ2, PCM 343, MLA Surf Ballast, Premium Sound.
