Originally posted by SurfTN
View Post
Cannot Fill Gas Tank on my R20 ... HELP!
Do they have that carbon cannister type thing or just a check valve?
If a check valve, my problem was solved with the Racor LG 100 fuel/air seperator.
Look at the pic I posted here and see if you have on that looks like the atwood one. Then read the boatus article linked. This upgrade has made filling up at the pump a much more enjoyable experience.
http://www.tigeowners.com/forum/show...to-Gas-Showers
Also, if you have the atwood one, you can try maybe putting in a straight fitting (removing check valve) to see if it then vents better and you can fill up and see if the problem disappears. If it does, then maybe try the Racor one I used based on the article.Mods: MLA BIG Ballast System (1800+ Custom sacs, 2 500 W705 sacs under bow), Duffy Surf Flap Mod, Trimmed Swim Deck, Top-Mount Starter
Originally posted by WABoating View Post
My point here is that the angle of the fuel tank can make a big difference while trying to fuel. If you have air at the front of the tank and there's no way for it to escape, you won't be able to fill your tank to capacity. This might not always be the reason, but it was definitely the problem for me yesterday.
Sent from my SM-N900T using TapatalkMods: MLA BIG Ballast System (1800+ Custom sacs, 2 500 W705 sacs under bow), Duffy Surf Flap Mod, Trimmed Swim Deck, Top-Mount Starter
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Originally posted by Stingreye View PostSure would have been nice if they vented the tank on the front and rear.
Those who encounter this problem frequently might consider lifting the floor panel to confirm 1) there is an air bubble trapped at the front of the tank, and 2) that the existing fuel level is above the fill hoses at the back.
Mentioned a few times but flipping the gas handle upside down works really well. My boat will not fill with out flipping it upside down.2016 Tige Z3, 2014 Tige Z3
Started having the same issue with my 2014 RZ2. It's definitely a vent line issue on mine. I first tried rerouting the vent line to be more in line with the filler tube to see if the sag in the line was causing an air lock. Went to fill it up and the pump shut off after about 1 1/2 gal. I lifted the floor, disconnected the vent line from the top of the tank and it filled with the pump at full pressure and no issues. I don't want to do this every time but, it beats taking a 1/2 hour to fill the tank which has happened in the past. I will be talking to the dealer about a fix.
Jeesh what a pain in the butt , just to fill a gas tank , are today's boats becoming so complicated , or is it all about making them as cheap as possible and gouging us poor boat nuts out of the last few dollars for a sport we love .
Sent from my HTC One_M8 using TapatalkLast edited by Z1Fan; 08-21-2014, 01:43 PM.
UPDATE ... and PROBLEM SOLVED! Thanks for everyone's input. I brought her to the dealer, who contaced Tige. Sounds like a known issue. Basically there is a valve in the gas tank fill tube that sences back pressure / when tank is full, but it needs to be at least a foot down the hose from the nozel in order to work properly. Mine was only about 4 inches. Tige sent the dealer some new hose and they moved the valve. I haven't picked up the boat yet, but have high hopes that this is the last time i have to worry about this problem. Thanks again and for those with similar issues I would take advantage of the off season and get it into the dealer before the weather gets nice.
Great to hear they got it fixed for you. As I was reading this I was reminded of some similar issues I experienced in the car business when working on cars, circumstances are slightly different, but did find on a few occasions a certain kind of spider would take up residence in a fuel tank vent or fuel evap vent hose / line and would make a web similar to the likes of an eardrum, and this would cause refueling issues and failed evap vent cycles causing check engine lights and excess tank pressure build up. Knowing how we store and cover our boats this is something to consider if the other things are found not to be the cause. I recall one car in particular I was working on and I removed the vent tube, I wasn't able to blow thru it, so I cut it open in the midlle and hundreds of tiny little spiders went scurying out of the tube.I don't want to go to work, take me wake surfing instead!
