speed set question
    speed set question
    My cruise on my boat has been acting funny lately. When a rider falls and we turn to go and get them when re accelerating the cruise will not activate causing the boat to over accelerate. Anyone had this problem before? The cruise has always had to be reset if you cut the boat off. Not sure if that is normal or not either
    Mine will occasionally do that but not very often. I do have to reset it like you said after shutting the engine down and starting back up even when the display shows the speed is set.
      When you set the speed does the bottom right button say "set" or "on"??
        When a rider falls and you stop and turn around to get them I have never had any issues. Anytime you turn the boat off yes, you will need to reset the speed set.
          @trashman I don't think we have the same setup mine does not have a indicator button it is all on the speedometer and it reads set and actual. Is there a control module I could check for loose connections or a sensor that reads the speed may not be reading? I have always assumed having to reset the cruise after cutting the boat off is normal but the new issue I would say is something wrong
