Sub floor access
    Sub floor access
    Is there any way to remove a section of floor to access the area under the floor between the stringers and the side of the boat on a 22V? I thought I remembered someone removing a section of floor in the locker to add bigger ballast bags but that may have been a different boat/forum.
    My boat has a pretty substantial lean towards the driver side so I am wondering if one side is filled with water soaked foam and just looking for a way to check it.
    The problem seems to be worse at speed so it may not be a weight issue at all but I wouldn’t mind seeing what is under there.
