Help - 2013 z1 dies. Radio works. Won't start
    At least it is super windy today
      I just feel like there is something missing.... With power to circuits up front, why won't anything power on????
        You could check the power on the ignition switch , it's very easy to check , yours won't comopletely look the same as I have an ebuttton installed
          No real power to those. Ignition?
            No power to which ? You should have 12 volts on one side of the switch , when you main switch is on at the back
              What switch?
              The battery switch is "on". We are testing the wires going into the ignition.
                The ignition switch
                  Very little juice going there. How much should be coming through?
                    You should have battery voltage on one side and none on the other when switch is off
                      We have .01v on one side. That's it.
                      The others give zero
                          Well that's a problem , you have to find out why , trace the wire , I belive the ignition switch is fused or breakered
                            We checked the ignition fuse on the engine and it is fine.
                              Solenoid on the starter possibly?
                                image.jpgCircuit breaker by the battery looks cracked. Is that how it should be?
