What can I use in a 6.0L GM?
Which Octane Fuel do you use ?
Wake HavasuTags: None
Re: Which Octane Fuel do you use ?
Originally posted by Wake Havasu
What can I use in a 6.0L GM?Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
I run 91 all the time. I began using it when it got really hot here (95+) and like the way it performed in the heat (higher octane = higher vaporization point) so I've kind of just stuck with it. Boat ran fantastic this weekend.
I have the Merc. 350 Mag so I guess I'll shut up now.Last edited by NICKYPOO; 06-05-2006, 03:23 PM.You'll get your chance, smart guy.
Well the only problem I see w/ running a higher octane is the dent in your pocket. Although I guess it's possible that if you've been running a higher octane the whole time and step down from say 91 to 87 and the computer had adjusted for the "good stuff"... I guess it's possible you could get a bit of knocking. I doubt it though.
Your boat's motor isn't a supercharged or turbocharged engine w/ the timing severly retarded, so the higher octane isn't really needed.Being a major OU fan and a staunch conservative.... I am perpetually vexed w/ the conundrum of who to hate more. Obama or the Univ. of Saxet.
Interestingly, I used 87 the first tank with no problems... Thought to myself....self, if 87 is good, then 89 should be better right???
I contend that the boat ran better on 87. Smoother acceleration and overall operation... My next tank will be 87 again and we'll see if my theory is correct. The advice from the dealer is 87...so hey, why not...
Being a drag racer as well as a Tige owner I can kinda explain the octane thing. The higher the octane rating the slower the explosion happens in the combustion chamber. On high compression race engines we want to be able to control the "explosion" or ignition of the fuel in the cylinders. 87 burns real easy so a hot spot on a piston can and will ignite the mixture prematurely..causing knocking and pinging- that is actually the "explosion" happening forcing the piston back down, but the crank and connecting rods are still mechanically forcing the piston up the piston rattles back and forth....bad deal. So with the high octane gas these hot spots on the pistons wont ignite the mixture.
So in theory, if you could have complete control over the cylinder and piston shapes, contures, and design-you would make more power with 87 because the flame travels faster....but in the real world i gotta pay $8.75 a gallon for 116 octane!!
I have the Merc 350 MPi and the manual says to use 87. I used to run 89 and 91 because it was the only thing I could get at the marina. While I was using the higher octane I noticed a black film on the transom. Every week I would clean the black film and rewax the transom, I thought it was a problem with the engine. A mechanic friend of mine told me that the black film is caused by running high octane in the Merc engine. I found this hard to believe but when I started running 87 octane the black film all but disappeared. Who knows? I do know that 87 is less expensive and the boat runs fine with it.-Tip
I ran 89 instead of the usuall 91 this last weekend and did not like it, or at least the boat didn't. It felt a tick week and didn't fire up nearly as quickly. With the 91 it's just a quick flick of the key and BLAP, she's a runnin'. Don't know if the 'puter was having trouble compensating or what but after a good solid year of 91, the Merc was a little upset with the 89. I guess it's spoiled.You'll get your chance, smart guy.
