I have a couple of minor issues on my new 2014 RZ2 and was hoping I could get some guidance here. I could take it back to my dealer but its sort of out of my way and don’t really want to drop it for a week or more. Also, I think I can handle these issues myself as they aren’t too detrimental. I posted a few other threads (ballast) and trailer issue but here are few more.
1. The TAPs arm is leaking hydraulic fluid (pink/red fluid) from the top of the arm. Its leaking from what appears to be the big screw top. I read some other threads on here that it might need to be tightened, a new seal or a rebuild kit?
2. The Speed set seems to vary and drop speed when I’m sacked out while wake boarding. I noticed that I had to really feather the throttle and watch the speed while towing someone. Is there an adjustment for this?
3. I noticed some water pouring out of the drive shaft seal/collar. Looks like it needs to be tightened or adjusted. Any input or recommendations on how to do this. My last RZ2 had some allen screws that had to be tightened, I wonder if this is the same process?
Thanks in advance.
Thanks in advance.
