Key alarm or warning beep not sounding anymore when starting Z1
    Hi guys, 3rd time out with my '08 Z1. I noticed this time, when I turned the key to the first position before starting the boat, I would not hear the usual alarm or beep sound and that the dash lights were slow to coming on. Anyone have this issue? Is there a setting that I changed to accidentally turn this alarm or beep warning off? Everything on the boat ran great.
    Thanks!
    I just started having same issue on my '08 RZ2. Any luck finding solution?
    Fat, Drunk, and Stupid is no way to go thru life.
    Dean Warmer '68
      No luck finding solution. I just am now use to not hearing it anymore when I start the engine, maybe it's a blessing cause I probably start that thing over a hundred times a day when I'm in the water.
