i think i have one, if thats all you need. My E series extras have gotten slim over the years.
Pull pin down and rotate rack. Yours could be locked up if it hasn't been oiled/used in a long time. If thats the case, take the assembly apart, grease/clean and put back together.
I'm also looking for rack parts - I need the bolt that is used to lock the swivel assembly in the 'outer' position. I also only have one rack 'finger'...i need another, because as it stands mine is useless. I have an eseries tower and bits & pieces of the system pictured.
