Guardian 500 Bilge pump
    Bilge died motor heats up but does not pump or spin the impeller
    2001 Tige 21V need new Guardian Bilge pump Can you still get the old Guardians with the internal foat.
    Its under the motor would just like to replace the motor and impeller and reuse the old floor housing
    Just glanced at bilge pumps on skidim.com site. This one says it is a direct replacement for the Guardian 500: http://www.skidim.com/prodinfo.asp?number=6031726
      Replaced mine last year. Bought on ebay, snapped the old one off the base and the new one in. Connected the wires and tadaaa, new bilge pump without going through the headache of attaching a new base to the hull. Just wish it was more than 500gph
        You can always add a second pump in an area that's a little easier to reach and gets more water, such as just forward of the fuel tank. Of course you need to pull the fuel tank out but that's easier than pulling the engine.
          That's what I did to my 08 Z1
            That's what I should have done.
