21V Trailer brakes???
    How do you adjust the brakes on a 21V trailer....2000 model but should be a pretty common trailer. I see a ton of them.
    This past weekend, towing back and forth to the lake when I would slow down, the brakes would like grab on and off....never locked up or anything. I added some brake fluid, because it was a little low, and that seemed to help some. What should I check for now????
    DC
    Probably have air in your brake lines. Drain them and refil like a car's hydrolic brakes. Or you could be like the guy I had to help get his boat into the stall, and his trailer would always slide when backing up and engage the brakes. I solved it by putting an 11mm socket so it couldn't slide, and the boat trailer place drilled a hole for a pin so when he backs up he installs it and it doesn't engage the brakes.
    Originally posted by G-MONEY
