Hey guys, I want to put a tower on my boat. I am sure this has been discussed a bunch of times, so maybe a link to another thread? It needs to have a bimini top also. The boat is new to me.IMG_0755.jpg
Help with what tower to buy.
I was faced with replacing the Metcraft tower on my boat this past winter (tower cracked at the end of the season last year). I looked at a bunch of universal towers (monster, Aerial, Roswell ect.) and there are many options to choose from. I scoured the past forums on tower replacements and in the end I bit the bullet and went with a Samson Blade tower. I was concerned with the stability and rattling that is associated with universal fit towers. The Samson towers are pricey, but they are rock solid. I was not disappointed with the service and quality.
If your on a budget I'd take a look at one called the Indy Pro series. I put one on my last Mastercraft and was quite happy with it. Nice and solid and installation was easy. Looks pretty similar to the Monsters but the joints are much better looking.
If you have a few more bucks to spend you can't go wrong with the Samson towers. Depending on how i like my E-series tower i may replace it with a Samson Blade next winter if the funds are available.
I was faced with this choice 2 years ago, after research I did find that the sampsons are the best but, with that being said, they are the most $$$. I ended up going with an arieal assult tower in black, came with two racks and LED light. It mounted right up with ease. I will say that the first year I used it the bolts did loosen and the tower had some side to side motion. At the end of the summer I took it apart and put the loctite on all the bolts. Now with 2 x xm9's, two wakeboards, and a custom bimini, it does have [I]some[I] movement in choppy water, but for the cost it does the job great! Although they have gone up in price since I bought one, I still think they are a good value. I am happy with my purchase. Its better than any metacraft tower I have seen. Ill try to get some pics up this saturday when I take it out. Hope this helps.
Oh, my next choice was going to be the Indy, there new one looks very solid.
I had a monster tower on my last boat and if your money conscious they are an ok tower. They do shift and make a lot of noise and you will constantly be tightening things on it. Even with Loctite on it. I had a couple breaks in it after 3 years and had to tear down, weld and re powder coat which is a pain!
I am pleased with my Tige E series tower and know that Samson makes a similar if not better tower that is available. The Samson towers are built to last hints the reason they are pricey. If you ever have to tear a cheap one down and redo it you will ask yourself why you didn't shell a little more cash the first time around. Just my $.02
