Finally picking up my 07 RZ2 on saturday (i hope). I'm in the process of ordering a few maintenance things online that i'd like to change and a few things i like to keep around, just in case. Some of this i can't find info on and would appreciate the help of you guys with similar boats. Its a 07 Rz2 with the 340HP Marine Power engine
1. Whats the raw water pump impeller i need?
2. Is there a automotive equivilent for the serpentine belt? There are no marine shops close to me so this would make things easy.
3. I'd like to replace the steering cable. Factory is a 18ft but most threads says to buy a 20ft. Teleflex model ssc15420 is correct?
4. Anyone know the water intake hose size? I'd like to install a flush kit and just not sure which to order.
5. Wheres the best place to order this stuff from? I'm in Canada but i get everything shipped to the Montana/Alberta border and pick it up there. Saves a lot of money. I've used Overtons in the past and they were ok, just slow. I've also used SkiDim in the past and they were ok.
Thanks guys! I may think of a few other things as they pop up and i appreciate the help.
