Had a rough start to the weekend. Put the boat in hit the key and the gauges came on but no start. Pulled the trailer out to check everything and then had no power to the gauges. Decided to replace the batteries and when I turned the key I got a low battery warning and no start! Come to find out the starter was shot. Only lasted about 40 hours and the tech said he was on his way to my neighbors to put a starter in his 2014 Z3. Thought I would post just in case others are having similar issues.
Rough start to the weekend.
Tigé Jedi
- Feb 2004
- 5557
- St. George, Utah
Would the 2013 have the PCM engine and the 2014 have Indmar? Bummer to lose the starter after such a short time. Does it get water splashed on it from the bilge?Be excellent to one another.
I had the same problem last year however, I could hear the solonoid clicking but it woundn't turn over. A local shop said it was prolly dirty brushes in the starter and reccomended pulling it off so they could test it on a table. Let us know what you find out! Has anybody removed a starter on a 343PCM RZ2? The starter is sim2010 Tige RZ2 "Fully Loaded" 650hrs
Surf Ballast & Enzo Bag - 1235 prop
Ugh! If it's anything like my Pcm 6l was I don't envy your position. The block mount on mine requires the muffler to be removed or engine pulled. My ring gear was toast and needed the motor pulled anyway. Boatwakes on here pulled my motor, had his machine shop machine on a new ring gear that supported the crusader (same company as pcm) top mount starter. My starter is now out of the bilge and a really easy fix if I have any starter problems. I plan to keep the boat a long time and just didn't like the starter in the bilge even though it's very common location it sounds like on the 6l motors.
Sent from my SM-N900T using TapatalkMods: MLA BIG Ballast System (1800+ Custom sacs, 2 500 W705 sacs under bow), Duffy Surf Flap Mod, Trimmed Swim Deck, Top-Mount Starter
