Although it seems like I've been on this site forever, I still have only ever used my new boat twice. However I should get it out in the next two weeks (finally). I have some newbie-ish questions and they are pretty random, so I figured I'd just start a thread for random questions. Feel free to add if you like. Just number your questions, so people can answer them.
1) Trailering - I've noticed that my board racks don't latch on the inside position. I need to flip them in for trailering because otherwise they will hit my shed when I park. (see pic). However when they are flipped in they smack the Rev 10's. Anyone have a solution to this? I was thinking of putting some foam tubing on the fingers to protect the speakers. As you can see, I just stuck some foam mats in there for now.
2) Water pooling in storage - As you can also see in the pic above, when it rains water always pools in the cover. It is right on either side, but the Alpha-Z. Any advice on how to prevent this?
3) While we are on the topic of rain, I notice that the boat gets wet inside whenever it rains. I think the reason is that rain hits the tower, then travels down the tower into the boat. The seal on the cover is shabby at best. Has anyone got a clever way to prevent this?
4) Removing Platform / Vx -
As you can see in the picture, there are 3 bolts and a pin on each side for both the Vx and the platform itself. I understood that it was "easy" to flip these both down or off for convenient storage. How do you do that? Do you just run with 1 bolt and a pin (in the case of Vx) or 2 bolts and a pin (in the case of the platform). I found that getting both of these off took a lot of effort and was nearly impossible to do alone.
5) Charging battery - if I want to trickle charge the battery to keep it topped up, where do I connect? My boat has the isolator circuit. It is as simple as + and - on either battery?
6) Surf boards in racks - I have the surf bimini, but given that its not that hot here in the summer, I doubt I'll have it up. I'd rather fit my boards into the racks. However the last board I did that with got really beat up. I ended up making a sleeve for it to sit in. Anyone have something clever to do the same? I obviously don't have the clamping racks.
I think that's all for now. I'm sure I'll have 10 more questions after I actually get to use the thing! 9 more days....
