Recently bought a 07 RZ2 with the factory ballast and i want to upgrade for more weight. My budget is $5-600 so no enzo sacs for now
. I'd like to keep it automated if possible, i hate manually filling sacs since we switch sides ALOT.
I have some sacs left over from my old boat:
1-integrated bow sac (w711)
2-400lb sacs (w713)
2-250lb sacs (w703)
1-750lb sac (w707)
If i can use these thats great but i can also sell them to add onto my budget a little.
What i was thinking so far is to replace the Tige bow sac with either the W711 (i think its bigger?) or with the 2 separate 400lb bags. There are separate fill and drains for the left and right so either option should work, though i may need to add vents (not sure about how its vented from factory).
I'm very stuck on what to do in the rear. I was thinking about moving the batteries, taps, and blower and pulling the factory tanks. Then using the existing pumps for a 750 or a 1100 in each locker. Then i can use the smaller 250 lb bags on or under the seats if i want to add a bit more sometimes and manually fill them. I'm not sure if this is the way to go or if there is something that will work better and not kill the bank account.
One problem i have is the boat is not actually here now but i want to get things straight in my mind so once its here i can get this installed ASAP and hit the water. So any help or input would be great.
2-400lb sacs (w713)
2-250lb sacs (w703)
1-750lb sac (w707)
