Originally posted by EricU
View Post
ACME Prop Group Buy? - Any interest?
I have one possible that just hit me up through text. 2 more and we are at the 20% mark!
Just sayinMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Ok, we are @ 9 confirmed, so 2 more and we will be @ 20%.
If no one has an objection, We will hold this for another day or so for those that are working out trailer clearance issues.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Ok, one more confirmed and we will be at the 20% mark!Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I would be in if I knew which prop to order!
I have an '09 22Ve, 350ci, 340hp PCM, bought it end of last year and only used it once. Won't be able to get to it until late May (ice still on lakes in Mich).
It probably has the stock prop. If I wanted to get a spare, which one is recommended? I probably will be doing mostly surfing and plan on adding ballast... or get a bunch of heavy friends.
Originally posted by ericinmich View PostI would be in if I knew which prop to order!
Originally posted by Av8tor View PostGive Acme a call, they are great to talk with. They'll let you know which prop will work the best.
Am I missing something on why not just order it there vs. a group buy?
Yes, call ACME and get their recommendation. Once you know what prop is on your boat, you can then decide which one will be the primary and which one is the spare. Most people run an upgrade dia/pitch prop, then tuck their stock or other away as the spare.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
