Last week when my buddy pulled the plug to stop filling the fat sac, the 12V adapter fell apart. The piece that goes to the Tsunami pump had the metal tip fall out and get stuck down in the 12V adapter plug. We didn't notice it until I went to plug it back in to drain the sack, and it wouldn't go down in far enough because there was a small piece of metal in there (the tip to the 12V adapter). Since then, my 12V power under the ignition has not worked, nor does my horn, right next to it. The ignition and everything else seems to work fine.
I climbed under there to try and see what was going on, the wires all look solid. Unfortunately, I can't even follow the wiring because it goes up into a huge bundle of wires, and I lose it there.
I suspect that it may have blown a fuse? Where would the fuse be for that, and would that explain it?
My boat is a 2005 24V.
