Went and bought the wood for my subwoofer enclosure today. It will be for the 10" factory kicker. I was able to find 13ply birch and will be working on this here in a week or 2. Couple questions before I start. The thread below is the one i'm going to try and match. The only issue i'm seeing is that the opening through the front flip up back rest is possibly smaller than the rz2 that this other one was was built for. I measured and it looks as if i'll have to be around 14"w x 14.75"h. Depth looks to be fine though. Is it ok to say that if its going to be slightly smaller on the width and height that I could just add some depth to it? I've been reading up and I just keep getting more confused. Any help would be great! Also, would it be easier to just leave the front panel off with the hole for the sub and just butt it up to the carpeted area to same time cutting a hole? Just glue the heck out of it and screw it together? Also, would I need to buy a speaker wire terminal or how do you run the speaker wire out without drilling a hole or running it through the port? Newbie here on this topic!
http://www.tigeowners.com/forum/show...ight=enclosure
