Jig saw works perfectly, I have cut thousands of square feet of this stuff for my crossfit gym.
RZR Surf Flap Mounting
Finished this over the weekend and I figure this is a good place to post it
My flap is made out of a heavy rubber shop type mat I purchased at home depot. I think it's 5/8 thick. Definitely not as stiff as 3/4 horse stall mat but it gets the job done. I really only need mine for the goofy side. Speed of about 11 goofy and taps at 2 my goofy shapes up nice with the mat knocking down the rooster tail that's the key for me. My mat is cut alittle longer than the bottom edge of of the taps plate in the 1 position.
Originally posted by laserfish View PostCan we get a couple more pics of the quick release that you built in? Is the flap held to the bracket only by the two pins at the end? Kind of like the idea of being able to remove mine as it is screwed to the bottom of my wood platform now. Amazing how they really work to smooth the wave.
The boat is already at the river for the summer, I'll take a few more pictures this weekend while I'm there.
I think if people surf this is a simple and must mod. I would have guessed the major boat brands would have copied it and made it look nicer by now. Simple and effective. I always assumed the vx was a "pretty" copy of the mod.Build thread: http://www.tigeowners.com/forum/showthread.php?14787-Duffy-s-2005-24v-wakesurfing-mod-thread&highlight=duffys+24v
Originally posted by cal-riss View Postthe flap is held by the 9 bolts. The pins at the end also go through the mat, but their primary function is holding the small "locking" bracket in place.
I want to start making a flap for my 09 22Ve but so far I'm a bit confused as to what shape/dimensions I should be making it after looking at all of the different threads? Should I try and cover damn near the whole left to right side of the platform given that I have the lip on my platform or should I stay within the brackets? I see others are anywhere from the whole width of the platform to 3'-4' wide. Obviously I can always cut down as I go but figured I try and get a good starting point. Length I'm not worried about as I can figure that out once I have the mat mounted and can see how far past the platform it comes and trim accordingly.
Originally posted by BCRider View PostI want to start making a flap for my 09 22Ve but so far I'm a bit confused as to what shape/dimensions I should be making it after looking at all of the different threads? Should I try and cover damn near the whole left to right side of the platform given that I have the lip on my platform or should I stay within the brackets? I see others are anywhere from the whole width of the platform to 3'-4' wide. Obviously I can always cut down as I go but figured I try and get a good starting point. Length I'm not worried about as I can figure that out once I have the mat mounted and can see how far past the platform it comes and trim accordingly.
