R20 Vector Tower Mirror
    Anybody know of a good tower mounted mirror to use on the R20 with the vector tower? I would like to get it up out of my line of site and have a wider field of view then the standard mirror. I have looked at a bunch online but I am not sure how they will work with the curve of the front tube of the tower.
    I like the PTM Edge Mirror.
      Thanks looks nice but seems like they only have windshield mounts or do you have a mount for that mirror that works with the tower? Thanks I may windup getting something like that just for a wider field of view. I really I want to get the mirror up higher and out if the way.
      What is the field do view on the standard mirror that comes with the boat?
        I don't know what the standard view is for the mirror on the current boat. Mine uses the arm from the tower and I replaced only the mirror with the PTM and have a lot wider viewing area. I can see the wakeboarder when they are out in the flats.
        Iwndr if you could use something like this and the PTM - http://www.ebay.com/itm/KRYPT-UNIVER...item4d15f7e4c3
          I called Monster and got quick release one from them. http://shop.monstertower.com/p-37-mo...cket-only.aspx
          I like the quick release feature to take it down while towing or storing. Its really easy.
          If my memory serves me correct, they had two different mounts to the tower depending on the curvature of the tube.
          I also needed an adapter to work with a ball and socket CIPA (its the same mounting as PTM, so the PTM mirror would work with Monster's mounts). I haven't used many different mirrors so I really can't comment. I do like having it up high vs the windshield for visibility.
