Why not use a fake a lake and run antifreeze through everything? Takes 2 minutes to do if you have help.
To Winterize Or Not To Winterize
Originally posted by loudelectronics View PostWhy not use a fake a lake and run antifreeze through everything? Takes 2 minutes to do if you have help.2009 RZ2, PCM 343, MLA Surf Ballast, Premium Sound.
I agree with all of the comments about draining the block. Only takes a few minutes once you are used to it and gives you the extra piece of mind. I typically do mine several times each winter because we end up going for a few boat rides over the course of the winter and I just drain it again when we are done.
For reference my dad has an I/O on a lift on lake LBJ and he did the heater in the engine compartment thing for many years with no issues. That was until the big freeze about two years ago when it was below freezing for several days in a row, power went out at their lake house and it cracked the block. Now he drains the block every winter.
Originally posted by chpthril View PostUsed oil is caustic and can pit the soft engine metals such as bearings and pistons.
Used oil contains hydrocarbons (unburned fuel) that can soften and swell rubber seals and gaskets
A crankcase with used oil contains condensation created by the heat up and cool down cycles.
Im a fan of changing before layup.2011 Tigé RZ4
www.re-viveupholstery.com
Originally posted by cpropes2005 View PostFor reference my dad has an I/O on a lift on lake LBJ and he did the heater in the engine compartment thing for many years with no issues. That was until the big freeze about two years ago when it was below freezing for several days in a row, power went out at their lake house and it cracked the block. Now he drains the block every winter.
I have a 1997 2200v and I live in Dallas. I have performed the same steps since 1997 and I have never had a problem.
1. Run ethanol remover / gas treatment for 20 minutes
2. Spray fogging oil into intake to prevent rust
3. Remove freeze plugs. Its an easy job
4. spray 303 aerpsoace vinyl protector all over the seats. This has extended the life of the vinyl. It prevents vinyl from drying out and cracking.
5. Put tarp on boat
6. removed batteries and put on a battery maintainer.
I never understood why you would change oils and let it sit for months building up condensation. For the summer time I change oils, fuel filter and every two years the impeller.Last edited by ktm450exc; 11-06-2013, 10:12 PM.
Originally posted by gcombe74 View Postwhat are the thoughts of changing or removing, but not refilling until spring? this goes back to that debate about the age of engine oil ext... but curious how you can get the best of both? just if you change now.. by the time spring rolls around... havent you exceeded the time based side of changing your oil? just looking for the best solution to this issue.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by Buckaroo View PostI just moved up to a 2009 22ve from a 2007. pcm now. What is different about draining the block on the pcm?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by loudelectronics View PostWhy not use a fake a lake and run antifreeze through everything? Takes 2 minutes to do if you have help.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
O have heard many sad stories of $6000 engine replacements due to unexpected freeze damage. Never had anyone tell me they regretted winterizing. Draining oil for the winter does not make sense. You need to run with fresh oil to flush out the acidic old oil
Sent from my HTC Sensation 4G using Tapatalk 4
http://www.bobistheoilguy.com/motor-oil-101/
I got this link on here one day. This is where I learned that mineral oil has a shelf life. My boat has had synthetic ever since. Excellent read if you've got the time.Last edited by JohnnieMo; 11-07-2013, 07:38 AM.
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Originally posted by chpthril View PostIf RE of leaving filed with freshly changed oil or leaving drained, im for leaving filled.
For those who are really super concerned about it: Just change the oil AGAIN in the Spring when you de-winterize the boat. You won't need to change the filter since it hasn't seen any oil circulation. A gallon of fresh Rotella T and a few minutes with an extraction pump and your worries are behind you.
Originally posted by ktm450exc View PostI have a 1997 2200v and I live in Dallas. I have performed the same steps since 1997 and I have never had a problem.
5. Put tarp on boat
If anyone has ever used their boat in the winter you will notice the vinyl is much stiffer and not as pliable as it is in the summer.
