While winterizing this year, I noticed that the little rubber end cap on the end of the steering cable near the rudder had come off the "cylinder" on that end of the cable. I'm pretty sure this means my cable has been exposed to bilge water, which means I'm headed for a new steering cable in the near future.
I put the end cap back on and wrapped it with a tyrap to keep it there. A few cycles of the cable showed it is staying in place, at least for now.
I helped a friend winterize his Mastercraft yesterday, and noticed that his steering cable has a zerk fitting on that cylinder so you can freshen the grease inside. No such fitting on mine, so I can't easily repack it and force out any water inside.
Question: What normally keeps that end cap on there? Is that cap coming off the primary failure mechanism for steering cables? If so, it seems like a tyrap would be a cheap insurance policy for a rather expensive cable.
