How to set the cruise control
    What is the simple way to set the cruise control from tige touch. Pls advise
    Go to speedset and press set when you reach desired speed!
      Dear Chris
      Thank you for yr advise.I want to know if it is set before the boat start or it should be set when u reach that desired speed in driving?
      As I used to set everything before drive, I go to profile and then click one profile in Radom and set the speed then press set , I saw the screen with speed engaged in green color but very often it did not work after I start to drive. That's why I want to know if it should be in driving. Many thx
        I always set it ahead of time before driving but if you turn off motor you have to reset it .
          It should work how you were doing it. I always set before driving. If its for my pull i set it before i get out of the drivers seat. Here is how i do it:
          1. Hit the speed set quick link button at the top.(left side top button, think it has a star on it)
          2. Hit the wakeboard green button. Far right circle should go green and say ON
          3. Use the up/down arrows to adjust to desired speed(22 is the wakeboard default, adjust from there)
          4. When you are ready just slam the throttle at least 3/4 of the way down and the computer should handle everything.
          If it doesn't work like that you have a problem with something.
            Thx a lot
