Originally posted by boardman74
View Post
Got my new fat sacs today!
2013 RZR w/ConvexVX
http://www.surfsupws.com http://facebook.com/surfsupwatersports
Originally posted by mdamon View PostI just received the Flyhigh W0005 84" bag for the starboard side of my RZR. It fills up most of the space under the bench seat, but I still have open storage under the captains chair. And I agree with zroutt, Mike's customer service is awesome! Mike also recommended and added two additional ports in the bag so i can use my dedicated fill and drain pumps as well as plumb it in to the hard tank like the factory has.
thanks
Originally posted by sa0303 View PostHow much does this bag help with your goofy side wave? i'm thinking of adding the same bag to help with that side, the regular side is money without it.
thanks
Originally posted by mdamon View PostI tried filing the rear bag up all the way and I did not have enough weight in the bow, I had the standard 400# plus about 200# more. After draining a little out of the rear corner (I probably ended up with 700-800#s) the wave was great and really long. Also had about 200 in the non surf side. Looking forward to playing with it more.
Mine (W005/ 930 lb 84") took over 10 minutes, probably close to 15 with a throw over the side 1200 Tsunami. Its not quick, But its a big sac. I only had the one so when we switched sides it took forever. Had to drain it, move it then refill. Really made me miss my boat with plumbed in sacs!!
It probably took 12 to 15 minutes to fill with the one pump. Once I connect the sac to the hard tank those pumps will help fill and drain once the hard tank is done so I am hoping under 10 minutes to fill or drain when done. I also have a Tsunami that I can throw over the side if I am in more of a hurry.
Originally posted by sa0303 View PostDo you have a pic of your surf flap? I have seen several on here but none on a 2012 platform. I was wondering how you connected it.
Let me know if you have any other questions.
