2006 20 V
    2006 20 V
    Looking to replace my teak swim step with a fiberglass one. Any idea where I can find one? Thanks
    I've seen a few roll through Craigslist. Aside from there, check with the dealer?
      Rhino line your teak platform. Will cost less
      Let it be!!!
        If you replace your Teak with a Fiberglass you WILL need to raise it up a few inches if you are used to a decent surf wave. I had an 05 with a fiberglass platform and once weighted it would cut the top of the wave off. I custom made new mounting brackets and raised the platform up 8" (it probably only needed 5" of lift).
          I have a 2013 Factory fiberglass swimplatform sitting in my garage. White in color with grey and black Tige SeaDek pad.
          2013 RZR w/ConvexVX
          http://www.surfsupws.com http://facebook.com/surfsupwatersports
            What would you take for it & where you located ?
