yes this is the port side... not sure on where they go I will have to look for you... and what do you mean disappears below the floor? under the seating ?
Hard tank drain pump location
Originally posted by Wickedcummins View Postyes this is the port side... not sure on where they go I will have to look for you... and what do you mean disappears below the floor? under the seating ?
Thanks,Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I removed my RZR floor to get access to hard tank drain pump. I am running new hoses to avoid water leakage from my drain pump as a result of larger custom bags. I will cross drain the hoses to the opposite side of boat. I am doing both vent and drain hoses on both sides.
Not too difficult of a job.Port rear tank pump.jpgStarboard rear tank pump.jpgNick
Dayton, Ohio
