Ok, help me out here. What does this button help with or improve? Does it give Tige Touch power at all times regardless of ignition key position....so the radio can alway stay on or your ballast pumps stay on when turning off the ignition key?
Tige Touch Screen - On/Off Button Install Phase 1 and 2
Originally posted by NHarp1 View PostOk, help me out here. What does this button help with or improve? Does it give Tige Touch power at all times regardless of ignition key position....so the radio can alway stay on or your ballast pumps stay on when turning off the ignition key?
Originally posted by jzts0214 View PostDoesn't the hours start when the key is in the on position. So if the button only starts and stops the engine would you rack up hours by having the key on?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Tigé Junkie
- May 2013
- 920
- Central MN
MN, did you do the install or did the boys at the dealership put that in? Have you had a chance to see how it works, considering the rumor that something needed to be changed in the TT interface? Very interested, as I am sure alot of us are!"I think I am pretty smart for an idiot"
Originally posted by Dandy View PostMN, did you do the install or did the boys at the dealership put that in? Have you had a chance to see how it works, considering the rumor that something needed to be changed in the TT interface? Very interested, as I am sure alot of us are!2013 Z3 - Electric blue and black
I received the button from Tige last Friday and the install was easy on my 2012 RZR, about 30 minutes to commit to drilling the hole and then 20 minutes to attach wires. I still can't figure out what the power wire for pin 20 on the viper is for, but I installed it.
We were out all weekend and the button is awesome! It is so nice to turn off the engine while switching riders and not have everything switch off.
The best is when you switch riders, start up the engine and the Tige SpeedSet is still set from the last rider.
