Tige Touch Screen - On/Off Button Install Phase 1 and 2
    All,
    Below is a procedure I received regarding the installation of a Tige Touch on/off Button.
    The procedure is not highly detailed and more information regarding the actual "Botton" is needed, but this is a good start.
    PHASE 1
    1. Start by marking the dash next to the ignition.
    2. Drill a 1/4" pilot hole.
    3. Cut a 3/4" hole using a hole saw. (note: cut through the vinyl in reverse then cut through the plastic in forward.)
    4. Move the bass control and USB port. Then cut a hole next to the ignition.
    4. Put the button through the dash and tighten the nut on the back.
    5. Remove the two red wires from the ignition and cut the eye off.
    6. Connect the red wires to the brown wire on the button.
    7. Connect the red wire on the button to the red stud above the medallion fuse box.
    8. connect the black wire on the button to the bus bar.
    Phase 2 will follow next.
    Phase 2 Instructions
    9. Remove the 20 pin connector from the viper.
    10. Remove the white plug from the connector. (note: use a safety pin to pry it out.)
    11. Feed the wire that came with the button through the #20 position (note: the positions are marked in the 4 corners on the back of the plug.)
    12. After pulling the wire all the way through put the white plug back in.
    13. Put the plug back in the viper and put a 1/4" spade on the wire then connect the wire to one of the four connectors on the fuse block.
    Again, More detail on the "Button" is needed, but this is a good start.
    Cheers,
    Ken
      According to my dealer, my "Button" is on the way. I'll post details as they become available.
      Ken
        This is a great, thanks for posting. Where is that fuse block located? What is the purpose of the white wire feeding into the medallion plug?
        2013 Z3 - Electric blue and black
          Ken,
          Thanks for posting, this is wonderful. Is the "button" a kit containing all of the necessary wires and connectors according to the instructions? If so, let us know if this kit has a part number that can be ordered. Hopefully Chpthril will also be putting a kit together as well. Tige gets enough $$ from us, if Chpthril puts something together I would support the "little guy"
            Is that "bass control" part of the standard audio system? Never seen that before on boats with Wetsounds amps.
              I don't have the "Button" kit just yet. It's on the way. I'll report back when I see it in person.
              The fuse block in the picture is up high under the dash above the steering controls.
              Not sure what the white wire does. It must have to do with turning on the rest of the system so the various function will register on the screen. It's just a guess, but I will figure it out when I see the kit.
              I'm told the cost is about $73 for the kit.
              I found the base control by accident and it works real well.
              Hope this helps,
              Ken
                Its been coming standard with every boat that gets the "Premium" system of 3 pair of in-boats, sub and Syn-6 amp. IMO, its in a bad spot and most dont know its there, including the dealers
                  Hay guys,
                  i am looking at a switch that comes in about different 5 colors of LED ring. Im waiting on some technical info about them as well as working out a bulk/wholesale price.
                    Our Tige dealer didn't point that out, we found out about it from our WetSounds dealer when they installed our WS420. Now Tige should put in a control to adjust the tower/boat speakers volume independant of eachother.
                      Hay guys,
                      Thanks Mike! I'm in for a white one if it's available.
                        red, green, yellow, orange, blue and yes, white
                          Blue or white would probably be my choice.
                            Probably be in for a blue as well once you find something out Mike.
                              I'd take a red
