I have taken delivery of a 2013 Z3 this spring and have been working with the Ballast Timer Set program to adjust to the sequenced time when the tanks are full and I had it set close enough to be satisfied. Last week my dealer did a software download and this screen seems to be removed and replaced with a screen I am not familiar with that is asking us to adjust by Volts? I believe this is volts as one of the new tanks is set at 3.7V? Can anyone clarify how I would set up the parameters it has confused me? Is it perhaps 3.7min? I neglected to take a picture of the screen sorry.
Ballast Timer Set Up 2013 Z3?
What ballast setup do you have?
You will want to go into the config screen and select ballast timers. You can adjust the timers from there.
My pro ballast requires 7 for rear and 5 for front.2016 Tige Z3, 2014 Tige Z3
I have a surf package on boat. The configure screen is something I was use to using I believe I had the rear set up at 5min and front at 3 and it worked well. The issue I have now is that screen does not se to be there anymore. It would appear we have the option to work with the settings but it does not seem to be in a "time" formate?? I wish I had taken a picture of it. I will get an image of this screen next weekend and will post.
