The perfect wave Beta tester..
    Looking for someone with an older RZ2 looking to test a wave shaper.. This will cost tho as air craft aluminum is spendy.. Let me know if your interested
    How old is old?
      How old is old, as the hull hasnt changed since its inception, just the swim flat form.
        Pre 11.. Need someone with the old brackets still attached to there boat.. I know the hull is the same
          I have a '09 and I'm just north of you
            let me know if you need another tester for 11 and newer! lol just kidding... i wish i had an older one i'd love to give it a whirl.
              Why not a 2005 24v?
                Originally posted by duffymahoney View Post
                Why not a 2005 24v?
                Thats actually next. My buddy has a 2010 ve Im gonna try it on as well =)
                  Do you anticipate any reprofiling for different hulls?
                  Is there going to be any additional bracing that will need to be added?
                  Do you think it'll be do-able on a old D-Drive?
                    They way I have this designed won't matter the hull.. Only thing that matters is the Brackets but that not a big issue either as I can change that real easy! The best part about this setup is it works with the chines but removes the intended purpose and uses them as a tool!
                      I don't have chines. I have spray pockets.
                        Hmm That might need some changes but I am sure it wouldn't be hard to change it up to work on older models.
                          Let me know when you're ready to test it on a RZR.
                            X2 on the RZR/R20 hull. I've got a 2011 that I'll beta test for you!
