Maybe a silly question but how often do you have to turn on your bilge when surfing. I have to check all my fittings since installing the bigger sacs. I loose some water out of the sacs for sure but after reading it sounds like it might be passive draining. The boat is new and only has about 15 hours on it. The auto ballast doesnt kick on and I only get water after filling up ballasts. I know some is acceptable but how much. Thanks
bilge
I don't get any water in the bilge from surfing. My cooler drains into the bilge at the end of the day so just a trickle comes out when I remove my drain plug. I guess it depends on how much and how bad you dunk the bow, leaks in the ballast and possibly a leak on the prop shaft seal or in the cooling system somewhere.2009 RZ2, PCM 343, MLA Surf Ballast, Premium Sound.
On a new boat there is no reason your bilge shouldn't be dry. Are you taking water over the bow or back while surfing? Just the act of surfing or filling draining sacs should not get any water in your bilge. If you sacs are leaking into the boat that is a problem and needs to be repaired. Not normal!
Tigé Jedi
- Jul 2010
- 4302
- TN USA
We get water from waves splashing over the tops of those little storage lockers above the swim deck. They drain into the bilge. I attached hoses so they run straight to the bottom, but still... fill them a few times and that bilge pump is going to come on!
Here's an inside view of what I'm talking about. You can see the hoses I added.
Mine takes on a lot of water under load. No weight in the boat it stays dry. Push it in the water and the bilge is always running. I had to put a 10 amp fuse in to prevent it from blowing all the time. The stock 3 amp would only last a ride and blow.2016 Tige Z3, 2014 Tige Z3
Originally posted by loudelectronics View PostMine takes on a lot of water under load. No weight in the boat it stays dry. Push it in the water and the bilge is always running. I had to put a 10 amp fuse in to prevent it from blowing all the time. The stock 3 amp would only last a ride and blow.2013 Z3 - Electric blue and black
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Originally posted by mnpracing View Postany idea why you take on water under load only?
This presumes that "under load" means "ballasted". If "under load" means "boat is moving", then his is a different problem.
Mine is only when ballasted for surfing or wakeboarding.
I have thought that it was water coming over the vents however when it would just randomly come on during a ride with out stopping I know it is coming in through the prop shaft or cooling system some how. It is just very hard to catch it.2016 Tige Z3, 2014 Tige Z3
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Originally posted by loudelectronics View PostI know it is coming in through the prop shaft or cooling system some how. It is just very hard to catch it.
